Antenna Cable Assembly
4 Answers 9 Score |
Uprgrading Storage of MacBook Pro 2019 |
2 Answers 10 Score |
My touchbar is flashing |
1 Answer 2 Score |
[Urgent] MacBook Pro 13" 2019 (A1989) not powering on!? |
3 Answers 3 Score |
MacBook Pro 2019 Model "Flexgate" appears and disappears |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
A1989 (EMC 3358 MacBookPro15,2) 2.4 GHz, A1989 (EMC 3358 MacBookPro15,2) 2.8 Ghz
Background and Identification
The 2019 update to the 13” MacBook Pro with Touch Bar is considered a “spec bump” update, meaning it’s mostly the same as the 2018 model, but comes with new 8th-generation “Coffee Lake” Intel Core i5 and Core i7 processor options. To identify your MacBook Pro, check the model number printed on the bottom cover.
With this model, Apple also took another stab at perfecting its troubled “butterfly” keyboard—still in its third generation, but now using one or more new, undisclosed materials designed to increase the reliability of the keyboard switches. The keyboard is still covered under Apple’s extended keyboard service program, meaning customers who experience keyboard problems should contact Apple for a free repair or replacement for up to four years after their original date of purchase.
Technical Specifications
Dimensions
- Height 0.59” (1.49 cm)
- Width 11.97” (30.41 cm)
- Depth 8.36” (21.24 cm)
- Weight 3.02 pounds (1.37 kg)
Display
- 13.3-inch LED-backlit IPS display
- 2560 x 1600 resolution, 227 ppi
- 500 nits brightness
- Wide color gamut (P3)
- True Tone technology
Processor
- Quad-core Intel Core i5 (2.4 GHz with Turbo Boost up to 4.1 GHz) or quad-core Intel Core i7 (2.8 GHz with Turbo Boost up to 4.7 GHz)
- 128 MB of eDRAM
- Intel Iris Plus Graphics 655 (integrated)
Memory
- 8 GB or 16 GB of 2133 MHz LPDDR3
Storage
- Non-removable SSD, configurable to 256 GB, 512 GB, 1 TB, or 2 TB
I/O
- Four Thunderbolt 3 (USB-C) ports
- 3.5 mm audio (headphone) jack
